da Green » 14 mag 2020, 7:45
** procedura fai da te resettaggio **
The next service due is shown on the matrix display when you first turn on the key. To reset the km or months until next service
1. Hold the “up” (1) and “down” (2) buttons and turn on the ignition;
2. Continue to hold the “up” (1) and “down” (2) buttons until the display cycles through all the menus;
3. Continue to hold the “up” (1) and “down” (2) buttons when the “setting menu” is reached;
4. After a few seconds the “setting menu” will change to allow you to choose the kilometers and months until next service;
5. Release the “up” (1) and “down” (2) buttons;
6. Use the "set" (3) button to increase the numbers. Keep going and the kilometers and months will cycle back around to 0 if you go past your choice.
