Ho raggruppato alcuni post per argomento per una più facile navigazione e per evitare duplicati. Spero sia utile. Chiaramente può essere integrato/modificato dai moderatori.
ACCESSORI
BARRE DI PROTEZIONE 1290S
https://www.myktm.it/viewtopic.php?f=107&t=43793
BARRE DI PROTEZIONE SUPPLEMENTARI: CONSIGLIO
https://www.myktm.it/viewtopic.php?f=107&t=45692
CAVALLETTO LATERALE CORTO
https://www.myktm.it/viewtopic.php?f=107&t=49607
CUPOLINO PIÙ ALTO - HELP ME
https://www.myktm.it/viewtopic.php?f=107&t=49657
CUPOLINO WRS
https://www.myktm.it/viewtopic.php?f=107&t=47294
60408001000 SUPPORTO CUPOLINO CREPATO
https://www.myktm.it/viewtopic.php?f=107&t=48935
PLEXIGLAS FARO ANTERIORE SADV S 1290
https://www.myktm.it/viewtopic.php?f=107&t=46024
[1290 S/R] PROTEZIONE FARO LED IN ALLUMINIO TOURATECH
https://www.myktm.it/viewtopic.php?f=107&t=46533
CONSIGLIO SELLA SADV1290
https://www.myktm.it/viewtopic.php?f=107&t=47423
COMPATIBILITÀ SELLE RISCALDATE 1190 1290
https://www.myktm.it/viewtopic.php?f=107&t=45097
COLLEGAMENTO SELLE ERGO 1290 SA S
https://www.myktm.it/viewtopic.php?f=107&t=45126
FARETTI PER SADV
https://www.myktm.it/viewtopic.php?f=107&t=44894
STAFFE PER FARETTI AFTERMARKET... IDEE?
https://www.myktm.it/viewtopic.php?f=107&t=48370
SOSTITUZIONE SPECCHIETTO RETROVISORE
https://www.myktm.it/viewtopic.php?f=107&t=46313
VALIGIE HEAVY DUTIES
https://www.myktm.it/viewtopic.php?f=107&t=46649
VALIGE GLOBESCOUT
https://www.myktm.it/viewtopic.php?f=107&t=46000
SUPPORTI VALIGE MYTECH
https://www.myktm.it/viewtopic.php?f=107&t=47942
BECCO ANTERIORE
https://www.myktm.it/viewtopic.php?f=107&t=46611
PARACOPPA MOTORE ALLUMINIO
https://www.myktm.it/viewtopic.php?f=107&t=48042
BORSE PER BARRE PARAMOTORE
https://www.myktm.it/viewtopic.php?f=107&t=46348
CALORE MOTORE
TANTE SOLUZIONI AL CALORE MA QUALE LA MIGLIORE?
https://www.myktm.it/viewtopic.php?f=107&t=50364
TEMPERATURA OLIO AD ANDATURA ALLEGRA.
https://www.myktm.it/viewtopic.php?f=107&t=47387
TEMPERATURA OLIO IMPAZZITA
https://www.myktm.it/viewtopic.php?f=107&t=46350
PROTEZIONI ALIEXPRESS PER CALORE
https://www.myktm.it/viewtopic.php?f=107&t=46450
CAMBIO ELETTRONICO
[HELP] VUOTO DI POTENZA QUANDO PRENDO UNA BUCA/TOMBINO!
https://www.myktm.it/viewtopic.php?f=107&t=49665
CAMBIO ELETTRONICO SI O NO
https://www.myktm.it/viewtopic.php?f=107&t=50416
CATENA – CORONA – PIGNONE
QUESTIONE DI DENTI: CAMBIO CORONA
https://www.myktm.it/viewtopic.php?f=107&t=46522
TENDITORI CATENE DISTRIBUZIONE 1290 SA
https://www.myktm.it/viewtopic.php?f=107&t=50276
UN RUMORE O NON UN RUMORE? [CATENA]
https://www.myktm.it/viewtopic.php?f=107&t=46867
ELETTRONICA
AGGIORNAMENTO ELETTRONICA SUPER ADVENTURE 1290/R
https://www.myktm.it/viewtopic.php?f=107&t=46819
RIMAPPATURA CENTRALINA ORIGINALE.
https://www.myktm.it/viewtopic.php?f=107&t=46688
Spia traction control
https://www.myktm.it/viewtopic.php?f=107&t=45330
FILTRO ARIA
RIMOZIONE SCATOLA DELL'ARIA AIRBOX [KIT ROTTWEILER]
https://www.myktm.it/viewtopic.php?f=107&t=50418
AIRBOX ROTTWEILER E RIMAPPATURE
https://www.myktm.it/viewtopic.php?f=107&t=45769
FILTRO BMC E SAS E PRESTAZIONI
https://www.myktm.it/viewtopic.php?f=107&t=50244
FILTRO BENZINA
SOSTITUZIONE FILTRO BENZINA
https://www.myktm.it/viewtopic.php?f=107&t=46194
FRENI
STRANO AVVISO, APPARSO PER IMPIANTO FRENANTE ANT.RE
https://www.myktm.it/viewtopic.php?f=107&t=48552
POMPA FRENO BREMBO RCS 19 CORSACORTA ORA SI CHE FRENA!
https://www.myktm.it/viewtopic.php?f=107&t=48683
DISCHI FRENO ANTERIORI 1290 SADV - PROBLEMA
https://www.myktm.it/viewtopic.php?f=107&t=45143
FADING FRENO POSTERIORE
https://www.myktm.it/viewtopic.php?f=107&t=47424
ANOMALIA INTERUTTORE FRENO
https://www.myktm.it/viewtopic.php?f=107&t=45911
IMPIANTO FRENANTE SUPER ADV S. FINALMENTE SI FRENA!!!
https://www.myktm.it/viewtopic.php?f=107&t=45587
COSTO PASTIGLIE FRENI
https://www.myktm.it/viewtopic.php?f=107&t=46952
PROBLEMA ABS FRENO ANTERIORE 1290S: NON FUNZIONA.
https://www.myktm.it/viewtopic.php?f=107&t=45739
FRIZIONE
OLIO FRIZIONE MAGURA
https://www.myktm.it/viewtopic.php?f=107&t=50442
FRIZIONE RUVIDA E CATENA CHE "TRASCINA"
https://www.myktm.it/viewtopic.php?f=107&t=48162
RUMORE FRIZIONE 1290SAS [VITI PARA MOTORE]
https://www.myktm.it/viewtopic.php?f=107&t=48943
GOMME – CERCHI
SALTELLAMENTO CERCHIO ANTERIORE 1290 SADV R
https://www.myktm.it/viewtopic.php?f=107&t=47229
SBACCHETTAMENTI
https://www.myktm.it/viewtopic.php?f=107&t=44380
SBACHETTA A 200 KM
https://www.myktm.it/viewtopic.php?f=107&t=45333
ULTIMI PASSI ELABORAZIONE 1290SA-R
https://www.myktm.it/viewtopic.php?f=107&t=50402
QUALI GOMME STRADALI PER 1290 S?
https://www.myktm.it/viewtopic.php?f=107&t=46781
TIRA A DESTRA....
https://www.myktm.it/viewtopic.php?f=107&t=45606
PATEMA GOMME
https://www.myktm.it/viewtopic.php?f=107&t=45363
ALLINEARE RUOTA POSTERIORE
https://www.myktm.it/viewtopic.php?f=107&t=48940
1290 S CAMBIARE I CERCHI IN LEGA CON QUELLI A RAGGI
https://www.myktm.it/viewtopic.php?f=107&t=48564
1290 SADV-R GOMME PIRELLI/METZELERE?!
https://www.myktm.it/viewtopic.php?f=107&t=47392
CONSUMO GOMMA ANTERIORE, PIRELLI ST2 FINITA A 6000KM
https://www.myktm.it/viewtopic.php?f=107&t=47483
PNEUMATICI UGUALI MA DIVERSI
https://www.myktm.it/viewtopic.php?f=107&t=46406
PERCORRENZA GOMME
https://www.myktm.it/viewtopic.php?f=107&t=44393
SOLO GOMMA POSTERIORE CONSUMATA, CHE FARE?
https://www.myktm.it/viewtopic.php?f=107&t=45422
METZELER ROADTEC 01
https://www.myktm.it/viewtopic.php?f=107&t=43833
LUCI
REGOLAZIONI LUCI
https://www.myktm.it/viewtopic.php?f=107&t=50405
OSCILLAZIONE GRUPPO FARO ANTERIORE 1290-R
https://www.myktm.it/viewtopic.php?f=107&t=50237
SMONTAGGIO FANALE SADV
https://www.myktm.it/viewtopic.php?f=107&t=46707
SOSPENSIONI
PERDITA OLIO MONO SADV 1290 - REVISIONE & CO.
https://www.myktm.it/viewtopic.php?f=107&t=45049
DOMANDA SU SETTAGGIO DEL "CARICO"
https://www.myktm.it/viewtopic.php?f=107&t=48222
FORCELLE ED AMMORTIZZATORE
https://www.myktm.it/viewtopic.php?f=107&t=50333
PERDITA OLIO STELI
https://www.myktm.it/viewtopic.php?f=107&t=49501
KIT ABBASSAMENTO
https://www.myktm.it/viewtopic.php?f=107&t=48233
SFILARE FORCELLE 1290 SADV ???? AVANTRENO LEGGERO
https://www.myktm.it/viewtopic.php?f=107&t=47303
CORSA FORCELLE
https://www.myktm.it/viewtopic.php?f=107&t=47394
SOSPENSIONI SEMIATTIVE SAS
https://www.myktm.it/viewtopic.php?f=107&t=44987
SETTING SOSPENSIONI SADV S USO IN CITTÀ
https://www.myktm.it/viewtopic.php?f=107&t=45354
TERMINALI
COLLETTORI DOBERMANN
https://www.myktm.it/viewtopic.php?f=107&t=48673
IAT BELINASSU
https://www.myktm.it/viewtopic.php?f=107&t=50367
RIMAPPARE O POWER COMMANDER? ARROW O DOBERMANN TITANIO?
https://www.myktm.it/viewtopic.php?f=107&t=50255
SOSTITUZIONE COLLETTORI
https://www.myktm.it/viewtopic.php?f=107&t=50295
FEEDBACK COLLETTORE CON ISOLAMENTO TERMICO 1290
https://www.myktm.it/viewtopic.php?f=107&t=49819
MODIFICA SCARICO ORIGINALE ADV 1290
https://www.myktm.it/viewtopic.php?f=107&t=49916
SCARICO: AKRAPOVIC O ARROW (O ALTRI)?
https://www.myktm.it/viewtopic.php?f=107&t=47129
SCARICO ROADSITALIA
https://www.myktm.it/viewtopic.php?f=107&t=47072
COLLETTORI
https://www.myktm.it/viewtopic.php?f=107&t=46805
TFT – NAVIGATORE - SETTAGGI
AIUTO CONFIGURAZIONE TELEFONO.
https://www.myktm.it/viewtopic.php?f=107&t=46506
TFT SPENTO
https://www.myktm.it/viewtopic.php?f=107&t=50390
COLLEGAMENTO SENA SRL A DASHBOARD
https://www.myktm.it/viewtopic.php?f=107&t=50039
NAVIGATORE 1290 ADVENTURE S
https://www.myktm.it/viewtopic.php?f=107&t=49982
RIDING MODE, CURVE E GAS
https://www.myktm.it/viewtopic.php?f=107&t=47615
NAVIGATORE BLOCCATO SU TFT
https://www.myktm.it/viewtopic.php?f=107&t=47515
DISPLAY TFT BOSCH
https://www.myktm.it/viewtopic.php?f=107&t=42440
VIBRAZIONE SOTTO TFT O ZONA STELI ATTORNO AI 3000 RPM
https://www.myktm.it/viewtopic.php?f=107&t=46622
VARIE
ERRORE MTC
https://www.myktm.it/viewtopic.php?f=107&t=47819
DONGLE
https://www.myktm.it/viewtopic.php?f=107&t=50408
RUMORE CON BUCHE O AVVALLAMENTI
https://www.myktm.it/viewtopic.php?f=107&t=50026
RIDE BY WIRE 1290
https://www.myktm.it/viewtopic.php?f=107&t=50089
VUOTI EROGAZIONE
https://www.myktm.it/viewtopic.php?f=107&t=50034
TAGLIANDI 1290 ADV
https://www.myktm.it/viewtopic.php?f=107&t=46947
CANISTER: L'INGOMBRO ECOLOGICO...
https://www.myktm.it/viewtopic.php?f=107&t=45599
